I've recently noticed that my CPU was hitting pretty extreme temperatures under full load.
Idle: 28.25°C (it's pretty warm today)
100% Load: 98.75°C
I stressed the CPU using Prime95 and monitoring temps using CAM.
My PC is a 6700K (running at stock speeds) being cooled with a Corsair H80i v2 with a single fan in pull configuration. It's in a BitFenix Prodigy chassis with plenty of fans circulating air inside the case. I have both the pump and the fan curves set to performance but it seems to make little difference. I have cleaned the whole PC paying particular attention to the rad and that may have made 1 or 2 degs of difference, but really, not much.
Short of putting another fan on the rad (which i really don't want to do) and reapplying the thermal paste, I'm not sure what else to do.
Thoughts?
100% Load: 98.75°C
Thoughts?
