- 12 Feb 2011
Hi,
I am a bit OCD with noise from my computer and am constantly trying to keep things running cool.
On the flip side I hate it when my temps start to rise so I am trying to achieve the best of both.
Here's a picture of the setup:
I have recently installed the tf3 570 which I love but it throws out air towards the front of the case which makes it fight with the airflow coming from the front 140 that's hidden behind the hdd cage.
I did have a 120 in the 5" drive bays but it was quite noisy so I removed the large 180mm from the back of the case a cable-tied it at the front thus hoping the achieve of good and quiet airflow.
I also have a 140 on the side door but I would like to remove this to keep everything quiet.
Could anyone suggest a good set-up that will allow good temps while being silent?
I would also like to upgrade the CPU cooler and I have looked at the antec 620 but I am unsure if this would have negative effects on the Mobo temp when compared to air cooling.
Thanks in advance for any help
