I don't know whether I'm overthinking this, any help would be appreciated..
Currently I have the Meshify C with everything running off motherboard fan headers:
Front Inlet - 2x 12cm Noctua NF-S12B FLX
Top Exhaust - 1x 14cm Noctua NF-P14 FLX
Rear Exhaust - 1x 12cm Noctua NF-S12B FLX
CPU Cooler - Corsair H80i + 2x NF-S12A FLX push/pull
"Hot" Components - i7-4770k, 980ti WindForce
Frankly it's all a little loud even at idle. The H80i isn't doing well at keeping temps down, even idling.
Was considering:
BE QUIET Dark Rock Pro 4 135 mm Silent Wings CPU cooler
Front Inlet - 2x be quiet! Silent Wings 3 140 mm PWM
Top Exhaust - 2x be quiet! Silent Wings 3 140 mm PWM
Rear Exhaust - 1x be quiet! Silent Wings 3 120 mm PWM
Don't know if this is
a) Overkill
b) Going to be any quieter on the motherboard headers and if so..
c) Are there any good budget fan controllers capable of 5x 4pin
Was considering:
a) Overkill
