For some reason, overclockers no longer stocks the gelid tranquillo. Can anyone else recommend a quiet (important- the quieter the better) and cheap (£25-30) cpu cooler with good cooling capabilities on the 2500k?
Also, off topic, I read that p1155 boards don't like high voltage ram, so I bought some low voltage 1.35v 1600mhz ddr3 ram, with the added benefit of less heat.
I couldn't find any specific information on whether it would be compatible or not, so I just took the risk and got it. Will it be compatible?
Thanks.
Thanks.
