I was wondering if you think by changing my case i would get better temperatures, (im not saying mine are bad just wondering if you think i could beat it on air?)
Case Antec P280
1 Nocuta Fan at 7V in the middle (behind drive cages)
2x Noctua Fan at 7V at the top
Tested at 22c Room Temperature
i7 3770k @ 4.5ghz
CPU: Idle 23-24c on all cores
CPU: Max 45 49 59 58 [tested using prime/bf4]
R9 280X OC
GPU: Idle 32c
GPU Max: 66c
if i changed my case, to something with better air flow like a carbide do you think i could reduce those?
Case Antec P280
i7 3770k @ 4.5ghz
R9 280X OC
GPU: Idle 32c
GPU Max: 66c
