Well, it works, but you need to be careful about condensation.
But if you are talking about watercooling, since you are on the watercooling section, you need to be careful about your liquid freezing.
I have always had my rads mounted in a box on a windowsill. All I have to do is vary the window opening to control water temps. Currently the outside temp is 1.1 degrees and with the window open just a crack my water temp is 8.5 degrees and my cpu temps are 31/30/33/27 when running IBT (delidded and lapped). When it get really cold in Jan-Feb I will be in the low 20's under load.
I have never had any problems with condensation in the 8 or so years I have been running with this cooling configuration.
