cooling pads
jcr
jcr
29 May 2011
southampton
are they any good?
i sit a 17inch laptop on my lap. when i use it for gaming it gets very hot and the fans are running at full tilt constantly.
is a cooling pad the answer, or are they too awkward for lap use?
You're probably blocking the cooling vents on the bottom on the laptop which would explain why it gets hot. You need something to lift it above your legs so air can get in.
They certainly can help, but I suppose it depends on how many vents the laptop has.
I used to use one to cool a router that got screaming hot in the summer, but that was well vented. Even a very moderate breeze cooled it a lot.
The pads I tried (not many) I thought were fairly poor for the money, but they did the job. I would not like to balance one on my knee, though.
These days I use a little plinth I made myself with a Noctua fan in it and a dedicated PSU. It's a lot quieter and should last longer. The fan barely turns (I run it at half it's normal voltage), but it knocks 20 degrees off the router's temperature.
laptop-
Acer Nitro 5- Nitro AN517-52
2 x 4GB DDR4 ram
256GB nvme
rtx 3060 6GB
i7-10750H
have sat laptop on a food tray. being a 17" model it rests on the lip of the tray leaving about half inch of space under it.
playing Disco Elysium im getting cpu temps upto 101 and gpu 95. are these temps acceptable?
thanks
laptop-
2 x 4GB DDR4 ram
256GB nvme
rtx 3060 6GB
i7-10750H
thanks
They are just about OK, but I (who am a cooling nut) would probably try a cooling pad. Get those temps down by 20 degrees and it's going to hopefully last a lot longer!
  • Like
Reactions: jcr
I would look into those fan curves. That does seem a bit toasty.
I got a helios 300 with an i7 9750 and leaving fan curve on auto coubwould be 90plus.. but I made sure fans on max (I play with head phones) when gaming. Plus cooling pad. Cpu doesn't go above 85c.
  • Like
Reactions: jcr
