- 31 Jan 2009
Apologies for my ignorance - but I'd be grateful for any help.
I am trying to replace a faulty cpu fan for a Intel Q9450. I am fitting it to new M/B - so I have no experience of 'typical' temperatures etc. on this M/B.
I would ideally like to have fitted an Arctic Cooling Freezer 7 Pro, but unfortunately I have limited space on the M/B (Gigabyte GA-EX38-DS5)and in the case (Antec Solo) and the Freezer 7 Pro just won't quite fit.
The alternative seem to be Arctic Cooling Alpine 7 Pro (which is more akin to the Intel stock cooler) or alternatively I noted the Cooler Master Hyper TX3 - but know nothing about this make/quality of this.
My query is that whilst the Freezer Pro was designed to dissipate heat for processors up to 130W, the Alpine 7 Pro only says it can do 90 Watts.
However the Q9450 has a TDP of 95 Watts.
Which is the important figure here? What happens if the fan cannot support the TDP of the processor? Is it a problem?
Can you confirm whatever - that the Alpine 7 Pro would be a cooler fan than the Intel stock one.
Thanks for any help you can give.
B.
B.
