Cooling Predicament!
2 Aug 2011
Liverpool
Just wondering what you guys think
what is better for managing the amount of cool airflow in a case
3 x fans on full pelt
or 6 x fans on low - med speed?
what you think?
Also depends if you prefer the lowest temperatures over low noise.
I'd go with 3 case fans on low but that's just me.
whatever you do, just make sure the money you spend on fans couldnt be better spent on a new case. for example, if your picking up 6 apache blacks then you might as well sell your current case and get a silverstone raven 3, or if your watercooling then a corsair 650D
