I've got this bundle for a friend
i7-930, Asus P6T Deluxe X58 mobo
In a bitfenix nova case using a Raijintek cooler
Case has 1 Corsair AF 120 rear exhaust and 1 Corsdair AF 120 front intake fan
Can anyone tell me if I can mount the cooler to have the fan pushing air out towards the exhaust rear fan? At the moment I have the cpu cooler fan forcing air down towards the gpu, which is causing overheating problems. I found that when mounting the cpu cooler the cooler would only face one way (up and down)
You can see from the pic I've got the cpu cooler fan on top, blowing down (2 long red arrows showing airflow) but that's blowing on to the gpu which is an internal exhauster itself (msi gaming 970) this just circulates hot air causing the cpu temps to hit 90 after playing GTA V for a while.
I want to be able to move the cpu cooler 90 degrees to have it sitting in pushing air through the cooler and out towards the rear exhaust like I have tried to show, also in the pic (3 red arrows and red box with the box being the fan)
You can see the attempt at what I want to do with the cooler lol, art not my strong point.
Bottom line is that I'm not sure I can mount the cooler the way I want to due to the mobo and the mobo mounting bracket. The backplate part of the cooler seems to only face that way (up and down) and won't let me have it facing right to left that I want. Is this a feature of that particular cooler or is it a mobo problem?
