Cooling question
10 Jun 2009
Darlington
Hi
My set up is detailed in my signature and I have a question that I would like the answer to, which is the best way to cool my pc. By that I mean which bios setting should I use, Q-Fan or Duty Cycle. I understand the merits of both however I am just looking for what you guys consider to be the best on the two options. Also in my bios setting if I enable Q-Fan I have the choice to monitor either the CPU or the Motherboard, again which one should I be monitoring? I have an Asus Extreme 2 Formula and Ive read many posts saying they run a little warm so would it be worthwhile to monitor the motherboard?
Your help is appreciated:D
