Hi, i'm thinking about changing some parts in my pc to make it cooler and quieter but not sure what I should change/add.
My cpu is a X2 3800+ @ 2.4ghz (stock volts) and it loads at 53c.
My motherboard temp is at 42c
Antec Smartpower 400W
Inno3D Geforce 6600 AGP (stock cooler)
Very cheap case
X2 3800+
Thermaltake Blue Orb II
Asrock 939 dual - No chipset fan
Can different cases make much difference to temps?
I bought the case for £7, it has a plastic window, no I/O panel with 2 case fans. When the case fans are removed the temp doesn't change and it's not any quieter.
Any ideas on what I should change to make it cooler/quieter?
Thanks
Very cheap case
X2 3800+
Thanks
Also got a Maxtor (6B160P0) @ 33°C & from the SpeedFan's S.M.A.R.T. web page it says the max should be 44°C! I'm suprised your not having any Hard Disk issues.
