Cooling the 5870
Man of Honour
17 Feb 2003
Chelmsford
I'm going to order a new 5870 to replace my 8800GTX. Up to now, I have a single watercooling loop for both CPU and GPU. Details in sig.
Now i'm going to put the CPU in the loop on it's own for a while so I can test the new card own it's own for while using the stock cooler, just in case of any problems before removing the stock cooler.. Then I was thinking of putting the card on it's own loop, so I was wondering if the following pump/radiator combination would be ok to cool the 5870?
Swiftech MCR220 QP Stack 240mm Radiator
XSPC 200 Bay Reservoir & Pump - Clear
200 lph seems pretty low to me considering my existing Dual bay res pumps 750 lph.
Dual bay res has a lot better pump in, I'd get that and as for your rad choice, I'd personally go a Black Ice over the Swiftech but a 240 is more than enough, I run my whole rig off a 360 and thats an i7 :p
The black ice rads that I've had in the past had a higher density of fins, so you'd need a higher pressure and faster spinning fan to get the best out of them. I'm now using rads like the XSPC ones that have a lower density of fins and they cool just as well but with lower spinning fans.
If you can fit in a thicker rad ie, 58mm of an RX rather than the 34mm of the swiftech you linked or the RS, then do it.
