cooling the cpu voltage regulator
29 Mar 2014
Hi
Currently specking a PC using an H100i in a bitfinix ronin in order to overclock what i am wondering about is, do I have to worry about airflow over the voltage regulator's heatsinks? or will there just be enough regardless
vregs are designed to handle more temperature than chips however you will benefit from keeping them cooler. something like a SpotCool will be perfectly sufficient.
