cooling
12 Apr 2009
Im getting a titan goliath with antec 902 and 4870/2 cards.I hear those cards run very hot , the room where the pc will be situated is a hot room .
Do you think there will be a danger of this system over heating?
Generally the side fan on the Antec does little to improve performance
Your best bet is just checking your temps to see how it's performing. If your room is really that hot just turn down your radiator or open a window. With the fans on high to be on the safe side I'd bet you're ok but keep an eye on it unless your room is like 30+ degrees.
wow I'm glad I was working while that video was playing - 4 minutes in before I had any idea what it had to do with the thread apart from its title :D
