I have an intake, and an exhaust.
Intake at the front, exhaust at the back.
My question is would it be beneficial to put an 80mm in the side and if so as exhaust or intake.
The 80mm sits directly above my Arctic Cooling.
My worries is if its exhaust and taking heat off the CPU then it may also effect the air flowing into the CPU fan.
http://i56.tinypic.com/qoa7hf.jpg
http://i54.tinypic.com/2nsu9tg.jpg
The CPU fan has to take air in from the bottom, if the fan above it is exhausting that air then the CPU cooler may struggle to intake air?
Thought it best to ask
(oh and before anyone says - yes I have sorted those messy wires out
