Cooling...
29 Jul 2011
Near Northants / MK
I need a helping hand, I've been out of the PC Market for some time now, but it looks like I'm going to have to put in another order for some cooling, two fans have gone in a row, and I'm out of reserves.
Currently I have 2x of these. But on top of that I need 2x 140mm's One for intake, one for exhaust, they don't need to be anything special, they just need to do a job properly :)
Also whilst I'm here, whats the best mid-range cpu cooler for i5 2500k at stock (will maybe overclock at a later date)?
Thanks for your help :)
If the TY-147 were in stock and you can use 151x141mm (2 sides are round) they are a steal
Best coolers for the money are
Thermalright Silver Arrow SB-E Extreme for £53.99
http://www.overclockers.co.uk/showproduct.php?prodid=HS-099-TR&groupid=701&catid=2330&subcat=2352
Phanteks TC14PE B-grade for £54.98
http://www.overclockers.co.uk/showproduct.php?prodid=BG-006-PT&groupid=595&catid=678
Alpenfohn K2 on special this week for £54.98
http://www.overclockers.co.uk/showproduct.php?prodid=HS-020-AL
Thanks for that, really detailed with a lot of choices :)
I've got a tube of MX-2 lying about, would that be ok?
Edit: Hmm, I'll measure up the holes...
MX-2 is fine. Most new coolers come with some anyway.
The SA SB-E Extreme has 2500rpm fans but you won't need them to run faster than 1300rpm... meaning they will be as quiet as normal SA SB-E cooler ;)
id avoid the spectre pro fans like the plague tbh. they make annoying clicking noises and are far from quiet while pushing not a lot of air.
ive been banging on about these fans for a while now, stick them on a fan controller and they are worth their weight in gold!
YOUR BASKET
1 x OcUK Tech Labs - Zaward Golf III Fan 120mm ZG3-120TL TRIPLE PACK £6.23
Total : £12.20 (includes shipping : £4.98).
also look at their range of fans Click Here
YOUR BASKET
I thought I was the only one with such problem :(
I used to have a Spectre fan and it clicked considerably loud, got a replacement and it done the same:(
I'd recommend looking at the Corsair AF fans. Super quiet and push a lot of air.
