Coolit ALC Vantage - Anybody using one?
3 Sep 2009
Anyone here got one?
How'd you get on with it, is it anygood with overclocking?
Recommendation with the Vantage is dont modify it to push pull becasue there is a sensor to detect coolant temp and adjust fan speed accordingly...
cheers.
From what I've read the ALC ECO and Vantage offer pretty much the same cooling performance. It might be easier to find overclocking results for the ECO :)
cheers.
Had one. Was great to begin with, worked really well etc.
Then the display unit packed in and it just beeped all the time the computer was on. RMA'd it and went for an air cooler.
However, I'm now on day 2 of using a Corsair H100 and (thus far) I can't fault it. A few people on here have also recommended Antec's versions to me.
General rule of thumb would be bigger radiator = better cooling = better overclocking.
EDIT: Corsair used to use CoolIt in making their HXX coolers. They have since switched to using Asetek, which I think it quite telling. OcUK don't stock CoolIt gear anymore either. Makes me wonder if there were a load of problems with them...
Hmmm....well I've switched back to air cooling for now...stock AMD heatsink and fan on my 1100T....I've got one of these being sent to me as an RMA from CoolIT, I did have an ECO on there....but hell it was noisy!
I thought coolit and corsair partered up to produce the H100 series....
I'm interested in the H100, the pump block looks noticeably slimmer than the coolit ECO...it won't fit in my case by look of it though.....think I will drop a thread over in water cooling forum...
