Coollaboratory Liquid Pro paste
8 Sep 2009
Has anybody used Coollaboratory Liquid Pro paste on your CPU? If you have would you say it is good?
Supposedly this is the king of CPU pastes.
It is the king, however it is very difficult to work with....and when you need to remove the heatsink it can be really hard as it pretty much brazes the CPU with the heatsink.
I would recommend against it, and from personal experience spending a lot on paste isn't that good. I usually just use Shin-Etsu paste as it's inexpensive and pretty good.
If your CPU or HS aren't flat it's a poor choice as the layer is so thin it won't make contact all over. Also it tends to weld both surfaces together and doesn't wipe off, needing Brasso and a lot of elbow grease to clean off. It also destroys aluminium!
Yeah i agree, your better off with a good quality alternative i personally use Artic - MX4 nice to work with and good quality and not to expensive
