Copper v Nickel Plated
Don
7 Aug 2003
Aberdeenshire
I'm seeing that there is a lot more all copper blocks (top and bottom) and they do seem to make a slight difference to cooling presumably due to the copper tops also aiding with cooling because of their improved heat conductivity compared to acetal/acrylic.
But has anyone seen any direct comparisons between nickel plated blocks and their copper equivalents?
I would say the difference is so small that is not to be taken into equation (nickel plating vs. bare copper). Plating is being measured in microns.
With all copper top you would gain 0,5 degree celsius.
There is experimental data out there somewhere that plots thermal resistance across an interface against mounting pressure for a range of materials. Unfortunately the only place I've seen this was in a couple of thermodynamics lectures, and I can't seem to hit upon the right search terms or textbooks to find a reproducible referance.
Still, I was astonished to see that for low mounting pressures, nickel plated copper - nickel plated copper has a lower resistance than copper to copper. The explanation being that electroplated nickel under pressure deforms to fill some of the voids in the joint to a greater extent than solid copper does.
How thermal interface material / solder affects this, I do not know. I imagine it decreases the difference between the two. I've mentioned this on these boards once or twice before, but without any form of reference it's hard to take me seriously. If therefore you do find any tables on thermal resistance at an interface between metals, please do post them, as it has important implications for lapping.
(To within the normal margins of error of computer watercooling though, I'd agree entirely that it's cosmetic.)
