Copy and paste code in VB Excel
18 Oct 2002
MK
I want to copy a range of cells from one sheet to another in the same work book.
I found out how to select a range
Application.Goto ActiveWorkbook.Sheets("Total").Range("C2:J3")
But then how do i copy it and paste it into a sheet called Index?
Thanks
Something like:
(don't know exactly)
Workbooks(fileyouwanttpasteinto).Activate
ActiveSheet.Paste
Mel P
Mel_P said:
Something like:
ActiveSheet.Paste
Mel P
you may also want to tpsecify the position where you want paste aswell. Have a look at offsets if u have time, otherwise just activate a cell.
That looks better - I haven't used Excel VBA for a while - there are usually several ways of getting to the same endpoint.
mel p
In the end, i selected the cells and used the function "Selection.copy"
Found it out by recording the macro and looking at the code :)
Is there a method to select cells with a certain value?
i.e. select all cells in range h5 to al5 with value 1? Then total them?
Ok, one more excel question!
How do i do an IF statment on a range of cells?
i.e. IF(a1:a12 = "H", b2 +1)
Comes up with "#value" error :(
Something like this?
Code:
=IF(COUNTIF(A1:A12,"=H"), B2+1, 0)
