Copy File and make any required directories
26 Aug 2012
North West
I'm trying to copy a file from a source path to a destination path and make any required directories in the destination path.
An example would be as below where the 'blah2' directory does not exist at the destination.
cp /etc/blah1/blah2/file1.file /opt/blah1/blah2/file1.file
I need this as I have a php web app that needs to cache certain things.
Any help would be much appreciated.
do you mean with cp or via php
For cp use cp --parents
so it would be with your example
Code:
cp --parents /etc/blah1/blah2/file1.file /opt/
That will create the required dirs if not there
Edit: having said that. It would create opt/etc/.....
Maybe cd into etc first then do the cp command
