I've just built a second PC and setup my first network, using a Netgear DGN2000 wireless router.
PC1 (see sig below) is running XP 32-bit and wired to the router.
PC2 is running Vista 64-bit with a Edimax EW-7728IN nMax wireless PCI adapter.
The problem is if I try and copy a file from PC1 to PC2 my mouse (MX revolution, wireless, don't know if that matters) suffers massive input lag, almost like the old days when something would be hammering the cpu (however there is no extra cpu usage when this is happening).
It also happens if I use PC2 to try and copy a file from PC1 to PC2, and go and look at PC1 its lagging.
Any copying from PC2 to PC1 is fine, none of these symptoms at all.
Does anyone know what the hell is going on?
