I have 3 HD's, all SATA. I also have an external hard drive. Copying files to and from the external is fine as normal but copying to and from the sata drives is very slow all of a sudden. I'm using Windows XP SP 2 by the way.
Example:
350mb file = 2 minutes -- Usually takes about 15-20 seconds
80mb file = 25 seconds -- Usually takes around 5 seconds
Doesn't sound that slow but it is when it comes down to larger files.
I don't have a new install or anything like that. Haven't formatted for about a year and a half (nearly had to format about a month ago but fixed a problem). Write cache is enabled on all files.
During the copying process the general speed of other applications and windows becomes slower as well.
Oh and a final point: the hard drive space on all drives is around 30% left or more. Opening files, accessing files is perfectly fine and nothing has changed in that regard so it wouldn't be a power or cable issue would it?
Example:
