Corded curtain tracks
Caporegime
13 May 2003
Warwickshire
Hi all
Bit of a long shot...we have corded curtains on the landing and one of the runners that holds the overlap arm has partially broken. This means that the overlap arm flops about thusly:
Any ideas where I can get a replacement? Here's a close up, where you can see the problem is that the right hand lug has snapped:
I've looked all over eBay and Google. Seems most are Swish or Integra, neither of which look like my fitting. I could just buy an entire new track, which I'd rather not do due to cost and fitting time as I've never installed one of these before, but it's what I'll do if I can't find one for a fiver somewhere.
Cheers.
Got a pic of the wall fixing the track is on .
If not, then is track metal or plastic.?
similar to some of the Interga corded track fittings.
Thanks.
Same fixings as used by Swish Valance/ Superluxe & Supreme Corded ranges.
The part is known as a Overlap Set .
EDIT: Swish might have change the design a bit, to something cheaper to make.
The fitting are Leverlock as used by Swish, don't think any one else used that type, having a think about that.
