Hi everyone,
I'm looking for a corded detail sander, but I can't seem to find something that fits what I want?
I had a Titan unit but velcro became worn at the pointed end, and it appears you can't order a replacement pad.
What I liked about the Titan was the ability to connect it to a vacuum, handy as my Vacmaster has a plug socket that turns the vacuum on when it detects a load i.e. when the sander is switched on.
I like this unit for two reasons 1) the ability to have a detail pad and a square pad and 2) you can buy replacement pads. However, I don't think you can connect a vacuum cleaner? Looks like it only has the filter box?
So is there anything 160w or greater that has replacement pads, is corded and can accept a vacuum?
