Core 2 5200 or 7400?
12 Feb 2009
I'm trying to decide on which processor go for. I'm going to try overclocking for the first time and after reading all about the 5200 I was going to get one and give it a shot. Partly due to if I manage to toast it, its no great loss as its cheap.
That said, I'm wondering whether its worth spending more and getting the 7400 instead? Will that CPU give a significant advantage when overclocking over the 5200?
thanks in advance :)
It will clock higher but it's up to you whether it's worth another £50. And as long as you stay sensible on the voltages when you overclock you aren't going to fry your chip.
Well I'm thinking that anything will be a good improvement over my existing Athlon 64 3500+ :)
My current thoughts are to go with the 5200 just now and then upgrade it in about 12 months to something better. Sound like a good plan?
I would say E5200. Either that or E8*00. The E7400 is too close to E8*00 money for me.
