- 19 Sep 2008
Hi guys,
Ok, so 1st off i know absoluteley naff all about OCing and i've only done this as an experiment since i plan on upgrading to an I7 920 (950 would be nice
or AMD AM3 955 at the end of the month anyway so if the mainboard only lasts a couple of weeks then i can live with it.
I found some help on various sites on the internet, specifically review sites, and to cut a long story short i have overclocked, at my 1st attempt, a stock E8500 3.16Ghz processor all the way up to 4.27Ghz using the following settings:
AI overclock tuner: manual, CPU Ratio Setting: 09.5, FSB Frequency: 450
CPU Voltage: 1.4V, Northbridge Voltage: 1.3V, FSB Termination Voltage: 1.2V
I've set this up and it has been running stable now for 8 hours or so with no crashes, bsods or bios failure's. All in all, i am well impressed considering that it is my first attempt at such a large overclock and that i don't know too much about how to lower or raise the core clock speed (infact nothing if i were honest and i know even less about what damage this is doing to my components)
My Overclocked rig consists of the following equipment:
Antec Skeleton Performance Chassis,
1200W Thermaltake Toughpower Modular PSU,
Intel Core 2 Duo E8500,
Zalman CNPS9500A-LED CPU Cooler,
Asus P5Q3 Deluxe P45 Motherboard,
4GB Corsair CM3X2046-1333C9DHX Dual Channel Memory.
As far as i am aware no other modifications need to be made to dram timings and everything can be left at it's default settings other than the settings that i have listed above.
I don't know if this will be useful to anyone here but if it is, good luck with overclocking you're system (although, by then i would have probably cooked my system if it carries on running at these kinds of speeds
if only i could get the FSB to go over 450)
laters,
Myth.
or AMD AM3 955 at the end of the month anyway so if the mainboard only lasts a couple of weeks then i can live with it.I found some help on various sites on the internet, specifically review sites, and to cut a long story short i have overclocked, at my 1st attempt, a stock E8500 3.16Ghz processor all the way up to 4.27Ghz using the following settings:
if only i could get the FSB to go over 450)laters,
Myth.
with my first OC I thought everything was fine and dandy until it failed ORTHOS 30 seconds in! haha.
