Core 2 Duo, £500 - possible?
4 Sep 2005
Bristol
Can this be done?
Needs:
CPU
Memory
Motherboard
Graphics
HDD
Case
PSU
Basically the whole kit and caboodle...
I was thinking E6300 and a 7600GT.. But other than that I'm not really sure.
Any help guys?
Cheers,
Naffa
GeIL 1GB (2x512MB) PC5300 667MHz Value DDR2 Dual Channel Kit £79.99
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard £84.99
Akasa AK-ZEN-01-BK Zen Black Case - No PSU £26.99
Samsung SpinPoint P HD080HJ 80GB SATA-II 8MB Cache - OEM £25.99
Leadtek GeForce 7600 GT 256MB SILENT Heatpipe GDDR3 HDTV/Dual DVI (PCI-Express) - Retail £93.99
Enermax Liberty 400W ELT400AWT ATX2.2 Modular SLI Compliant PSU £39.99
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - Retail £105.99
Total : £550.93 inc VAT
This is my first time spec'ing but i think it look's ok.
Anyway if you are planing on overclocking i would suggest buying the e6300 OEM and getting a decent cpu cooler.
It is quite possible, this won't be a great system for overclocking but there is a bit of potential and you get a good graphics card into the bargain. I just read that you don't need an optical drive so you are under budget by £20 or so.
Asrock Conroe945G-DVI (Socket 775) PCI-Express DDR2 Motherboard £44.99
(£52.86) £44.99
(£52.86)
NEC AD5170 18x18 DVD±RW Dual Layer ReWriter (Silver) - OEM £16.99
(£19.96) £16.99
(£19.96)
Intel Core 2 DUO E6300 "LGA775 Allendale" 1.86GHz (1066FSB) - OEM £93.99
(£110.44) £93.99
(£110.44)
Antec NSK4400 Mini Tower Case - 380W SmartPower PSU £46.99
(£55.21) £46.99
(£55.21)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) £13.99
(£16.44) £13.99
(£16.44)
Corsair 1GB DDR2 Value Select PC5300 Dual Channel Kit (2x512MB) (VS1GBKIT667D2) ( £72.99
(£85.76) £72.99
(£85.76)
(£30.54) £25.99
(£30.54)
OcUK GeForce 7900 GS 256MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail £99.99
(£117.49) £99.99
(£117.49)
Sub Total : £415.92
Shipping cost assumes delivery to UK Mainland with:
City Link Parcel Next Day (Delivered Mon-Fri)
(This can be changed during checkout) Shipping : £9.95
Vat : £74.53
Total : £500.40
