Core 2 Duo Temps
Don
5 Oct 2005
Liverpool
Alright People....
One of those days... nothing to do, well, nothing I want to be doing so just surfing in the CPU sub forum... anyway my question...
I have overclocked my CPU to 3.8... but after reading some of these threads I'm worried about the temps... so let me know what you think....
Idle: 38c
Orthos: 65 to 67c
What do you all think??
Stelly
Not too bad stelly but there does seem to be quite a large jump from idle to load. Mine idles at 40c and jumps to 51c under orthos, my old e6600 made a similar jump of 10c or so but you are talking about a jump of almost 30c. Is that on air because mine is on water?
Cheers Webbo...
I didnt think it was bad was just checking... it doesnt start off that high, but the problem is I'm in the box room and it heats up a lot... that coupled with the 680i, 8800GTX, 7 x HDD I suppose that its going to get toasty... its on a water loop only doing the CPU 120.2 with ambers...
I'm thinking about doing a water change tomorrow though... its been like 6 months
Add me to your msn mate... got a few more questions... stel_26 at hotmail dot com :)
Stelly
Soon ill be sub zero with my temps when i get this phase installed. :D
How does 73c grab you? Running dual instances of orthos on all four cores! :eek:
easyrider said:
Was,
Decided to get it reworked for silence. :)
Stelly and W3bbo can you not discuss my business on the open forums pls?
Thanks
Sorry consider me told off :(
Wont happen again
Stelly
