Core i5 power = 112W
23 Feb 2003
When working my CPU (Prime95, etc), my CPU shows up as 112 watts in HWMonitor. I thought the maximum power was 95 w?
I seem to remember it used to show 95 stable, but now it just hops up to 112.xx watts
No, stock speeds. If I disable the power saving options in BIOS, the power is steady 112.x W. If I enable power saving options, then it drops to very low wattage, but does increase to 112.x W (again) when running something like Prime95 blend test.
Hotwired, what's your max power when running all cores??
Thanks
Stays at 112ish watts no matter what unless in power saving. In the above case it was overclocked to 3.6 and still 112 watts. At stock still 112.
It's odd, I've had a look and some online screengrabs of OCed i5 CPUs in hwmonitor show 95 W min/max. I'm sure mine used to sit at 95 W. Also pretty sure my min core voltage in idle is <1v, will have a look tomorrow evening when I'm back home.
Reason I'm concerned is that in idle the CPU seems to choke the video card / system causing BSOD. Stressing the system is fine, no instability! Although I freaked when Prime95 failed instantly on all cores, but that was solved by bumping memory voltage up to recommended spec (1.65 V).
My i860 at stock goes up to 111W in Hardware Monitor, should have same TDP as i750. For some reason i got a minimum reading of -0.77W, so maybe my processor is a power source at minimum :)
TDP and power consumption are 2 completely different things. TDP means the maximum heat the cpu will produce (as in waste energy), aka ineffenciency. Add that to the useful energy and you've got the power consumption
Also, how is it possible for software to know power comsumption?:confused:Thats impossible...
Not entirely impossible but unlikely. The motherboard would need to be measuring the current draw on the voltage rails supplying the processor at the socket and then somehow software would need to tap into the reporting of that function but I doubt any motherboards can do that.
speedfan/ hwmonitor are trash programs.
and btw lots of motherboards can accurately measure power draw...it's not that hard. x38/p45 and anything after that measures current draw no problem.
And superweza is right, TDP is much different than actual power draw.
According to my Mac Pro sensors with a 2.66Ghz i7:
Idle: 10-20W
Load (20% CPU time): 50W (It kicks out of full power saving mode here I think!)
Full load (100% CPU time): 80W.
Those numbers are what you really want to be heading for!
Idle: 10-20W
You're using a different program and a different chip.
How can anyone be heading towards a default wattage different to the default wattage they have? It's what it is. The only real question is how to read it correctly.
They are still the "numbers you should be looking for".
In fact I should in theory be using MORE power as I have HT.
Your program is wrong, mine is in the right ballpark.
Any links to any programs, I'd be interested see my usage - DFI X38 :)
A CPU is totally 100% inefficient, the power a CPU uses is entirely output as heat. For a stock CPU the power consumption shouldn't exceed the TDP, I suspect the software is just plain wrong in this case (there are current/voltage sensor that allow it to work it out).
