Core i7 920 DO overclock
27 Dec 2009
Did anybody get the Core i7 920 DO overclocked system when it came out? If so, what are your bios settings?
Full Spec:
CPU: Core i7 920 DO 2.67
Mobo: Gigabyte EX58-UD5
Memory: 6 gig Corsair XMS3
Naaa nuthin like that, I got an overclocked system about 6/8 months ago, I was on the forums the other day and asked "how do I know that it IS overclocked?" ... I ran CPUZ and prime95 and it turned out that it either wasn't overclocked or it had gone back to default. The guys have worked out a profile for me but the bios is rejecting it as too much of an overclock. The original spec was for a Core i7 920 2.67 running at 4 Ghz ... it was at stock settings and with the new bios it is at 2.76 ... I want to get it sorted and was just wondering if anybody had the same system ...
Have a look in the "SERVICE and RETURNS" section of the forums ...
When you flashed to the new bios (that is what I understood to have happened here) the motherboard does tend to reset to default.
If you are not sorted as yet, please post back here and I am sure we can work out how to get your system back to the purchased spec.
I have a very similar system so will be able to assist here. :)
The ocuk profile may still be there. Press f12 (or is it f11) and see what's there.
The old profile might not work on a later bios revision though and that's why ocuk dint guarantee the bundles once you update bios.
