So I replaced my old Core i7 5820K Haswell-E with a Core i7 6900K Broadwell-E and it's immediately clear that this new CPU gets hot (22nm vs 14nm), therefore I'd like to ask what is the max safe temperature for Broadwell-E to run at ?
I tried looking at the data sheet for the CPU at Intel but it didn't say anything about the max temperature.
The reason I'm asking is because I'm running the i7 6900K at 4.0GHz 1.252volts (auto setting) and after 6 hours of OCCT 4.5.1 the hottest cores (2 of them) hits 83°c and the rest around 78°c - this is around 166watt power consumption on the CPU according to HWmonitor.
Is this "safe" enough as for temperatures ?
For normal use with gaming, videorendering etc the temperatures are down in the 50°c range.
I'm aware lower is better, but if the temperatures are acceptable during such a long stress test, I won't run out spending £60 on a cooler.
BTW I tried setting the voltage to "adaptive" but for some reason this doesn't work like on the Haswell CPU, if I set an adaptive setting it still uses 1.252v at load totally disregarding the values I put in.
I am using a Phanteks PH-TC12DX cooler at the moment (the one pictures on the right), but if needed better cooling I'd pick up a Phanteks PH-TC14PE (the left one pictured).
** Do Not Hotlink images **
- I maybe I'll cash out for the larger Phanteks PH-TC14PE around christmas time when the upgrade itch comes again
