Core i7 Extreme Vs Core 2 Quad Extreme
9 Nov 2003
Leeds
Some interesting food for thought for you guys on what gains Core i7 has actually made.
Two systems both with clock speeds of 3.30GHz, one with a Core i7 Extreme 965 coupled with 6GB the other a Core 2 Quad Extreme QX9650 with 8GB.
Both systems used 3x Nvidia GTX 280 graphics cards on benchmarks where the CPU should be the limiting factor.
Have a look at these babies:
QX9650 @ 3.30GHz
i7 965 @ 3.30GHz
A good little comparisson, thought it may be interesting to see what a decent clocked Core 2 rig scores with similar hardware and what it would take to match the i7 3.30GHz...
QX9650 @ 4.20GHz
Even at 4.20GHz the Core 2 is still bottlenecking the graphics cards in Tri-Sli. The Core i7 gear although pricey certainly has Core 2 beaten.
From the results above to get a similar GPU score in Vantage with Core 2 as the i7 rig the Core 2 would have to be clocked at 5.10GHz or beyond.
OP
9 Nov 2003
Leeds
quite impressive, have you done much overclocking with the I7? 3.3 seems like a fairly low clock speed yet it still looks a great score. And have you done realy life tests with it eg. gaming/Photoshop ect.
We have had them for months, the chip will do 4.00GHz on air when pushed.
The idea of this chip was to show what the 920 can do when clocked as these are hitting above 3.30GHz day in day out. ;)
Lot of chip for the money depending on how you look at it. Have some Devil May Cry 4 benchmarks too:
965 i7 @ 3.30GHz
QX9650 @ 4.20GHz
Same sort of results with DMC4 benchmark.
1920x1200 - 16xQ - Vsync off - 60FPS Disable - All on Super High (Maximum Settings)
Keep in mind that the 3.30GHz i7 chip I have here can do 3.93GHz quite easily on a Akasa Nero cooler and 4.00GHz when the volts are really flying.
Caporegime
20 Jan 2005
Co Durham
Still fail to see why you are doing tri sli tbh. There has already been plenty of reviews with dual and tri-sli.
I would have thought a lot of people would like to see if it made any difference with their sole gtx280 or 4870x2 on a clock per clock basis with a core 2 quad extreme.
3 Jan 2006
Is it just me or are there no benchmark pics for QX9650??
Yes under tri/quad sli the difference is immense, I'd imagine people with such setups will have the money for Core i7 too. But for us normal folks with single/dual gpus the difference would be a lot smaller.
19 Nov 2008
QX9650 @ 3.30GHz
i7 965 @ 3.30GHz
QX9650 @ 4.20GHz
where is the other 2 screen shots?
21 Sep 2008
Which memory and what where the timings used for both these rigs please?
Nice resluts btw, shows of the true power of i7 in tri-sli.
12 May 2006
UK
It would be nice if you could also do the same benchmarks but with 2x Nvidia GTX 280 graphics cards, as most people with a fair amount of money will probably go for 2x high end graphics cards, as tri-sli is very expensive, and out of reach for most.
I've seen a few people here with 2x graphics cards in their systems, but i haven`t seen any that have tri-sli.
