- 9 Mar 2008
Hi,
Just finished building an i7 system, and currently got it running prime95 with the processor set to completely stock settings. Im currently getting temperatures of between 57C and 65C on each core, with hyperthreading enabled. Is this a little high? The processor is cooled by a TRUE with 2 noctua fans in a push pull configuration. One case fan isnt working due to incompetance (!), so i imagine temps may drop slightly with a bit more airflow, but it still seems quite high to me...
On a side note, im also slightly worried i have not mounted the TRUE tightly enough... I tightened the heatsink until it would not move laterally or twist, but there was still a lot of give left in the screws. Obviously i was wary of overtightening, but i recall seeing people using washers to improve tightness further, which suggests to me that maybe i have not done the thing up tightly enough!
Cheers, any help/advice is appreciated.
EDIT: Its not quite stock actually - it seems to have defaulted to the 21x multiplier, giving a clock of 2800 Mhz without me changing anything (no voltage increase ets).
