Hi,
I just got one of these last week for a new build from you guys and I'm having issues with a number of the cores running 15-20 degrees hotter than the others.
With no overclocking Realbench the cores are averaging 45-50 degrees however there are four that run into 55 - 60.
When overclocked the same cores go to 90-100 degrees where as the rest of them sit at 70-75 degrees.
If it's normal then please forgive my ignorance as this is one of my first overclocked builds however if not any advice on what I might try to fix it would be great.
