6 Feb 2012 at 20:03 #1 Mrnob Mrnob Associate Joined 17 Nov 2011 Posts 336 Location Birmingham On my 1100t i get higher cpu temp compared to the core temps which can be 10 - 15c diff. Which should i be following? my guess is the cpu temp.
6 Feb 2012 at 20:05 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent What program's are you using to check the temps.
6 Feb 2012 at 20:07 #3 Mrnob Mrnob Associate OP Joined 17 Nov 2011 Posts 336 Location Birmingham Hi, ive been using CPUID hardware monitor ,aida64 and core temp.
7 Feb 2012 at 00:32 #4 Mrnob Mrnob Associate OP Joined 17 Nov 2011 Posts 336 Location Birmingham cores showing 28c in idle and cpu 41c, seems bit high with this cooler to me if im to follow the cpu temp.
