Hi all I have posted this in General Hardware earlier but didn't know if anyone here has any more suggestions...
I have just built a new pc (Asus P5Q Intel P45 775 - Dual core E5200 2.50ghz) and when I run Real Temp, core 0 = 52o and core 1 = 31o, why is core 0 so high? Is it an inaccurate reading as when I test the sensors with the same program Core 0 has movement of 0 and core 1 has movement of 5?
I have not overclocked anything so everything is standard, I also have the Akasa AK-965 CPU Cooler. Should I try and replace the heatsink with less paste, although I'm sure I used a pretty minimilistic amount first time!
I am going to resit the cpu, heatsink and apply an even smaller amount of paste to it and also check to make sure bios is up-to-date later tonight. I am just a bit unsure how I am supposed to know if the chip has a faulty sensor or not as it worries me in case I start to overclock and it actually is a correct reading
Also, does a temp of 31o for core 1 sound about right for the cooler I am using? Thanks in advance!
