*Core Temp v0.98 out*
Cob
Cob
30 Jul 2006
Antrim town
It be here.
Version 0.98 - 23rd April, 2008
- Fix: Core Temp sometimes crashes when another program tries to access the log file. - Still needs further testing.
- Add: Show load percentage per core.
- Add: Adjustable Tj.Max value via *.INI file.
- Add: Option to start Core Temp with Windows.
- Add: Support new Intel Mobile processors
- Change: Maximum logging interval is now 99999ms instead of 9999ms.
- Change: Log file layout. Shows current temperature, high\low temperature, core load, CPU speed.
Happy you can now manually change the TJ Max. It's been previously reading my E2180's at 85c instead of 100c.
