Core temperatures ?
16 Nov 2008
Hi everyone,
I have small problem with E8500 core temperatures on P5Q Deluxe. My processor have E0 stepping, and all core temperature measuring programs shows, that both cores stuck on 42C.CPU temperature are shown corectly.
I was thinking for over clocking that processor, but for that you have to know you core temperatures. Any one have same problem before and maybe have solution for that.
I have latest BIOS for that mobo, system is stable.Using XP pack3.
Thanks.
What programs are you using to measure the temperature?
Try RealTemp, but follow the calibration tips first.
Bear in mind that all the programs are as good (or bad) as the temperature reported by the CPU. The temperature is only accurate at close to the Tj max.
I was using Real temp, Core Temp, Speed fan - all the same, only Speed fan give to me 37C, but they stuck is well.
Can be Faulty CPU ?
My E8600 was or I should say has the same problem, at stock the temps stay at 36 & 37 deg c full load or part load.
Spoke to Intel and ask for a RMA all thay kept saying is I should talk to the vendors of the software core temp, real temp, HW monitor, Everest and also ask Gigabyte to check for any possible problems or updates regards the BIOS.
Gave up in the end, overclocked the cpu to 4.4ghz with 1.33v and I now get temperature movement of 10c~.
You saying that I have to forget the that core temperatures and go for over clock ?
By the way, that will be my first attempt to do that… any suggestions ?
use white thermal paste and drop small amount and then spread all the core area very thinner and then install heatsink that what i do that - it keep low than 35oC - it stay 19oC <> 28oC all time. I dont leave wee drop in the middle and then put on heatsink - better spread all the core very thinner.
I used X2 6400+ with Cool N` Quiet
My shows on idle 22C. I think is good enough ..
hi mate, i have just O/C my E8500 to 3,8ghz-1600fsb-1,28V runs as good as Liona sings,lol
odle temp 34C, full load 45C...i use intel stock cooler.
as you have same E8500 i can give you SETTINGS and you will try and see what happens, but everything should be fine...
Hi,
this is my O/C setting...
AI Overclock tuner: Manual
CPU Ratio Setting:9.5
FSB Strap to North Bridge:400
FSB Frequency:400
PCI-E Frequency:100
DRAM Frequency: DDR2 - 800Mhz
DRAM CLK Skew on Channel A1:AUTO
DRAM CLK Skew on Channel A2:AUTO
DRAM CLK Skew on Channel B1:AUTO
DRAM CLK Skew on Channel B2:AUTO
DRAM Timing Control:MANUAL
1st Information :
CAS# Latency:5
DRAM RAS# to CAS# Delay:4
DRAM RAS# Precharge:4
DRAM RAS# Activate to Precharge:15
RAS# to RAS# Delay :AUTO
Row Refresh Cycle Time:AUTO
Write Recovery Time:AUTO
Read to Precharge Time:AUTO
2nd Information :
READ to WRITE Delay (S/D):AUTO
Write to Read Delay (S):AUTO
WRITE to READ Delay (D):AUTO
READ to READ Delay (S):AUTO
READ to READ Delay (D):AUTO
WRITE to WRITE Delay (S):AUTO
WRITE to WRITE Delay (D):AUTO
3rd Information :
WRITE to PRE Delay:AUTO
READ to PRE Delay:AUTO
PRE to PRE Delay:AUTO
ALL PRE to ACT Delay:AUTO
ALL PRE to REF Delay:AUTO
DRAM Static Read Control:AUTO
DRAM Read Training:AUTO
MEM. OC Charger:AUTO
AI Clock Twister:Stronger - Seems OK
AI Transaction Booster:AUTO - Maybe tighten this later - not too knowledgeable on this one
Common Performance:not shown as selected AUTO
Pull-In of CHA PH1:not shown as selected AUTO
Pull-In of CHA PH2:not shown as selected AUTO
Pull-In of CHA PH3:not shown as selected AUTO
Pull-In of CHA PH4:not shown as selected AUTO
Pull-In of CHB PH1:not shown as selected AUTO
Pull-In of CHB PH2:not shown as selected AUTO
Pull-In of CHB PH3:not shown as selected AUTO
Pull-In of CHB PH4:not shown as selected AUTO
CPU Voltage:1.28
CPU GTL Voltage Reference (0/2):AUTO
CPU GTL Voltage Reference (1/3):AUTO
CPU PLL Voltage:AUTO
FSB Termination Voltage:AUTO
DRAM Voltage:2.1
NB Voltage:AUTO
NB GTL Reference:AUTO try to set it at lowest after AUTO-if system won't work well,set to auto
SBridge Voltage:AUTO (same as above)
PCIE SATA Voltage:AUTO (same as above)
Load Line Calibration:AUTO
CPU Spread Spectrum:AUTO
PCIE Spread Spectrum:AUTO
CPU Clock Skew :AUTO
NB Clock Skew :AUTO
Advance CPU Settings
CPU VID: Disabled
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
soon i will update, but fot now it is fine.
try to set up NB voltages, and different voltages in that sections...when i do more options etc. will ad everything here.
Thanks for all, I will try when have time, my AI Lock twister set to performance…no problem.
Video card is fine, I did some testing’s – they are good….well I think. I find out that cart is very silence, and on load 68 C, but no problem because custom cooler.
Look there…only wiring is not professional.. but I happy what I have…
http://public.fotki.com/Doomas39/kompas/
heh...i am from Latvia :)
ok, when you try it, let me know.
PS. how to ad this information about computer's specs? ( you gave with red color)
Nice to see some neighbours there, try to go to your user profile and look for signature, just add there what you want.. that’s it..
