- 7 Dec 2008
- Newcastle, UK
Hi all,
Before I begin; my PC spec:
Intel Corei7 920 (C0, not D so 20x Multi) 2.6Ghz.
Thermal Take TruBlack 120 Cooler with 120mm fan
6GB G-Skill DDR3-1600 (3x2GB)
Asus P6T Deluxe Motherboard
2 x NVidia GTX 460 (SLI)
850w PSU
Now down to the issue. I'm attempting to over clock my CPU to 4.0Ghz with acceptable temperatures; on air cooling. I'm told it's possible on air-cooling; however I would be willing to go down to 3.8Ghz if that helped my situation.
At 4.0Ghz or 3.8Ghz I'm idling at 50-57c and under 100% with Prime95 it quickly raises to 99/100 at which time I stop it since that obviously too high.
even at 3.2Ghz I'm idling at 47-50c and hitting a max of 80c on Prime95; which for such a low overclock seems unacceptable.
Now there is always the possibility I need to clean and re-sit my heat sink; I think I was too liberal with the thermal paste when I originally put it on and this will be investigated tonight.
However do any of you kind folk have a cooler recommendation for over clocking at 4.0Ghz while keeping in mind I would like to avoid water cooling; budget constraints etc..etc..
I also have a feeling my case may not be roomy enough for decent air-flow and cabled management. I've had to shove excess cable into empty drive bays which blocking the front case fans a bit. So with this is mind a reasonably priced PC case recommendation would also be helpful.
Thanks for any assistance any of you can provide
850w PSU
