Corel Draw Expert help
14 Nov 2002
Under the Hill
I am having trouble laying out a brochure in Corel Draw X3. All goes well until I print and I lose a chunk of the image on the right hand side, but can find no way of adjusting the marging, the help file seems pretty useless tbh. Is there anybody with a few minutes to spare who could setup the page for me if I email it.
I'm completely self taught, so anybody with reasonable know how should be able to do it quickly, at least in comparison to the time eating monster this has become for me :(
Thanks for any help :)
Double click on the shadow part of your page and you will see the OPTIONS box.
Highlight PAGE and tick the SHOW PRINTABLE AREA box and if you keep in those lines you should be OK.
hi, I've already done that, but for some reason the printable area removes a large portion of the document on the right hand side.
actually, I've found a workaround. I published to pdf and got it printed from acrobat.
Yeah, the prinable area is too small. There is a huge area on the right that it would not let me print on even though it was 30mm inside the page edge.
