corel draw / vector programs
18 Oct 2002
anyone here use corel draw or a similar vector prog.
I have a few vector images that im going to put onto one sheet to print out, and some of them have over 2000 objects in them - so adding quite a few onto a a4 page causes quite a lot of slow down.
Does anyone know if it is possible to somehow merge/combine similar objects or combine into one object with out it messing up (using the combine or weld option in corel causes only one part of it to be seen)
