Corel Draw X3
19 Jan 2007
Northampton
Hello chaps
Quick question for all the software guru's in here:
Corel X3 ? Worth the cash ?
I had Corel 4 (on Windows 3.1!!) and Corel 8 thinking of upgrading.
Are there any good all in one alternatives ?
Ta.
Try the Demo!... just download it from Corels Website and give it a go for 30 days!... If you like it and think its worth it them just contact Corel and buy a key to make it legit!...
I've used Corel since v4 and its got better and better (if you ignore v9 which was Crap!)... I use it a lot and actually have X3... I thought it was worth it after doing the above!! :)
Thanks for that, I will download it this evening and give it a whirl for a few days, I was unaware they did demos.
