Corel Paint Shop Pro X Free
It asks for a Serial when you close the program!!...
It does ask for a serial, but from my understanding a serial is not needed for extended use i.e. it does not stop working after a certain number of days...it also allows to create a (Coral) account to download "extras"...
As regards stopping it asking you for it, I would think removing a registry key would do the trick, but don't ask me which one...
Are you using it jbloggs? It is incredibly annyoing and I'm sure my mum will seriously not approve lol. I'll have a peak in RegEdit but will not change anything.
To remove nag screen (on exit) do the following:
Procedure to remove nag screen:
1. After installing, open the following file in Notepad:
C:\Program Files\Corel\Corel Paint Shop Pro X\PCUUI\Container.htm
2. Erase all the text, replace it with the following code:
<script type="text/javascript">
location="pcucmd://Cancel?confirm=no";
</script>
Save the file
I've posted it a number of times on this forum and you're the first person to actually see it.!
It has mr bloggs , if you didn't get you've lost it . It was a good offer and it works perfectly . It's just over 100MB , someone must have uploaded it somewhere . It's worth getting.
Anyone know what 'Corel Media One' is??.. cos the link now has the Standard (Lexar Partner) version of that!!!... :)
