Corel Paint Shop Pro?
The current version (11.11) is not fully compatible. Corel have said that a Vista update will be available this week.
Biscuity said:
Hi
Any Corel Paint Shop Pro Photo XI users? I just upgraded for Vista compatibility, The new Paint Shop Pro seems a little unstable though. :(
I use Corel PSP XI on XP and it's perfectly stable, best photo editor IMO :) I always go :eek: when I try and find my way around Adobe Photoshop.
I used version 9 & it was great. Since Corel got their mitts on it, it's got a bit bloated IMHO.
For instance, uploading JPG photos to the 'puter using the Vista wizard from a Compact Flash card. This works perfectly in Vista, but open Corel PPP & the catalogue shows the new photos as blank images (with a cross). Open the images to edit them & they are then fine.
Doubel click an image in the Corel PPP catalogue & the image opens behind the catalogue window. What's that all about? :confused:
