Corel wordperfect 8 issue with formulas
1 Sep 2005
Hi
Wonder if anyone used to be good with this. Got a user who is using this and has upgraded to windows 7 from XP.
Everything works however the formulas dont seem to be working. I have checked and they are correct and work if you right click and select calculate however they dont work automatically as expected.
Done a test install on a XP machine and using the same invoice, the calcs work fine.
Any ideas would be appreciated.
cheers
