Corepad Skatez
19 Nov 2008
Has anyone used these mousefeet? The feet on my current Steelseries Sensei are trashed and I desperately need a new set, but neither Steelseries or any distributor I can find have had any replacement feet in stock since forever and the Corepad Skatez are the only things I can find that are shaped to fit the Sensei feet.
cant you just buy some teflon tape and cut it to size?
make sure you dont buy plumpers teflon tape that has no sticky side unless you are going to glue it yourself.
far cheaper than buying the overpriced branded crap aswell
