Permabanned
- 19 Jun 2007
- InURmama
QUOTED :
" A new version of the very compact CPU temperature application known as CoreTemp has now been released. The 0.99.1 update comes with quite a few changes including:
- Fix: Layout when using upto 125% DPI.
- Fix: Layout problem and extra systemtray icons with Phenom.
- Fix: Potential crashes while saving a register dump file.
- Fix: Core Temp icon wasn't showing in About box.
- Fix: Menu shortcut keys were not available for all menu items.
- Fix: A few old unnoticable bugs.
- Add: Initial Intel Nehalem support.
- Add: Initial support for AMD's Griffin cores - Untested.
- Add: Improved Intel Atom support.
- Add: Support latest AMD K8 CPUs.
- Add: Support for HyperThreaded CPUs. Core Temp will only display the physical cores and average load on each core.
- Add: Support for Pentium E5000 series.
- Add: Display core and thread count per CPU.
- Add: GUI Adjustments of Temperature offset and G15 applet via the Settings window.
- Add: Create a screenshot function. Access from "Options" menu or by F9 shortcut.
- Add: Shortcut key for register dump file: F7.
- Add: Update register dump output: APIC ID, CPU number, Core number, Thread number.
- Change: Move all settings to the ini file out of the registry.
- Change: Rename ini file to CoreTemp.ini.
- Change: Temperature offset adjustment works for AMD CPUs as well.
- Change: Atom Tj.Max adjusted for more accurate readings.
- Change: Cleaned up code a little bit "
http://www.alcpu.com/CoreTemp/
