CoreTemp or AsusProbe
21 Jan 2007
Ireland
Hey guys
Does AsusProbe give a true reading of core temps ? I remember reading before it was out by +10c . AsusProbe is showing my i7 @ 51c Stock and Coretemp 0.99.4 shows 40c Stock ..... I am using a Tuniq Tower 120 cooler .
What do you think ?
Hi,
Thanks . Is 40c about right so at idle ? My gut feeling is I used to much artic silver when attaching the heatsink , but would rather not strip it down again.
cheers!
Thanks . I tried RealTemp and it showed the same (40c)
When I clicked "Sensor Test" the temps jumped up to 55c for about 5 seconds then back to 40c again .... I tried the Prime95 test and its showing 58-60c accross the cores ...
Look ok with that cooler or should I reseat ?
Ok thanks . I was expecting lower with that cooler as I wanted to probably overclock it at some point once it settles. Cheers for the replies though !!
